lwells
Dec 30, 2017Aspirant
LB2120 not booting / unknown LED pattern
Hi I have an issue with an LB2120 LTE modem (LB2120-100AUS - H/W 1.0(0701)). Once switched on, the power LED comes on for a moment or two, and then the modem displays the following LED sequen...
JasonN
Apr 26, 2018NETGEAR Employee Retired
Hi Bowlo,
Thank you for your response. Have you tried using a different Ethernet cable?
Please let me know. :]
- Jason N
Bowlo
Apr 26, 2018Aspirant
Yes I tried a different cable. I was using the one that came with it at the time.
The device completely locked up and nothing changed its lockup status.
I hope you can figure it out to save others having the same issue as its a good router.
The dealer was happy to replace it.
