alanmercer56
May 14, 2020Tutor
LB2120 Not connecting
Have been using the 4G router for over year without issues. I don't use failover - so just the mobile network . As from 2 days ago the modem is not connecting to the internet. Message = "Mobile Br...
cbrassel
Jun 15, 2020Aspirant
Hi,
do you have any update ?
I have the same problem (with FREE provider) the 4G stop's working, and it seem's along the same date as you (i'm using it as backup so i have not detected the exact time the service disrupted).
somebody have any idea how to debug this ?
Regard's
Claude
- alanmercer56Jun 15, 2020Tutor
Hello Claude,
No - no update - the modem still does not connect to the data network (3G, 4G etc)
In the end I had to buy a new LB2120 - which works fine with the same SIM, antennae etc.
It would be great if someone on the community was able to help?
Best Regards,
Alan
- cbrasselJun 16, 2020Aspirant
Finally I have resolve the problem ..
A factory configuration reset did the trick, now everything is working again ..
- alanmercer56Jun 16, 2020Tutor
I tried that - no difference! Perhaps I will try again, and again...
Glad that your issue is solved.
Alan
