super_gromit
Jun 06, 2022Follower
lb2120 orange light no 4g connection
i have a lb2120 that i have been using as a fall over wan connection on my pfsense router for over a year and it has worked perfectly up until a day ago when it dropped the mobile connection and now the power light remains orange. i have tried a factory reset, using a different sim card and checking for updates and none are found. this seems like a common problem with them just failing like this with no real resolution to the problem. are there any tricks or tips to try and revive it
No RepliesBe the first to reply
