NetPro
Jun 07, 2020Follower
LB2120 SMS alerts failing but testing works
I setup this modem a few weeks ago and it actually works great as a failover.
Using Mint Moble (T-Mobile infrastructure) and the only thing I cannot get to work is the SMS alerts when the Spectrun wired link fails or when data usage goes above what I have preset for an alert.
Now, the strange things is, testing SMS manually works great both ways (instantly) so I know the network and my LTE plan works fine.
Have done a couple of factory resets but no cigar. I am using it in bridge mode with an EdgeRouter 4 and failover and fail back works flawlessly, just no SMS alerts of any of the activities one can select to be alerted on.
Open to any ideas here.
Thanks!
1 Reply
- itzamiguelAspirant
i have the exact same situation, so probably will be looking into having an alert on the dyndns side which i have setup to notify me when the IP address has changed since the SMS alerts aren't working.
By any chance have you found a solution on your side?
