TCNash
Sep 16, 2019Follower
LB2120 Static Route Config?
I have a LB2120 setup in router mode as 10.10.1.254/24. I need to set a static route for all of 10.10.0.0 to be routed to layer 3 switch at 10.10.1.1. I don't see an option to set up a static route like this. Are static routes supported on this model???
1 Reply
Please post about this over in the mobile router/hot spot/modem forum:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Good Luck.
TCNash wrote:I have a LB2120 setup in router mode as 10.10.1.254/24. I need to set a static route for all of 10.10.0.0 to be routed to layer 3 switch at 10.10.1.1. I don't see an option to set up a static route like this. Are static routes supported on this model???
