2DogsMonty
Sep 25, 2021Aspirant
Leaving MR2100 connected to power
Would it harm the battery if I left my MR2100 permanently connected to mains power? Cheers, Bill
michaelkenward
Sep 26, 2021Guru - Experienced User
That's a mobile modem router.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
