marksbury's avatar
marksbury
Live Stream RTMP from GoPro using Netgear Nighthawk M5
Equipment: GoPro 9 Samsung Galaxy S21+ Netgear Nighthawk M5 Hotspot   I am trying to get my GoPro to connect to the Nighthawk to live stream an event. Every time I try to connect, the GoPro Quik...
  • marksbury's avatar
    marksbury
    Apr 05, 2023
    After a lot of digging and testing, calling tech support lines, I found that the problem was actually on the T-Mobile side.  For whatever reason, although they could not confirm this, they are blocking the RTMP stream.  I ended up switching to AT&T and everything connected exactly as expected.
    Side note: It's odd that T-Mobile was blocking the RTMP stream from the hotspot, but they do not block it from my phone's hotspot.
