marksbury
Apr 05, 2023Aspirant
Live Stream RTMP from GoPro using Netgear Nighthawk M5
Equipment: GoPro 9 Samsung Galaxy S21+ Netgear Nighthawk M5 Hotspot I am trying to get my GoPro to connect to the Nighthawk to live stream an event. Every time I try to connect, the GoPro Quik...
- Apr 05, 2023
After a lot of digging and testing, calling tech support lines, I found that the problem was actually on the T-Mobile side. For whatever reason, although they could not confirm this, they are blocking the RTMP stream. I ended up switching to AT&T and everything connected exactly as expected.
Side note: It's odd that T-Mobile was blocking the RTMP stream from the hotspot, but they do not block it from my phone's hotspot.
michaelkenward
Apr 05, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. The MR5100 is a mobile router.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
marksbury
