cerylidae22
Mar 05, 2021Follower
LM 1200 Failover
Recently bought LM1200 for use specifically as a failover. Connected the device, using a line in from my router to the WAN port and ran a line from the LAN port to my PC. I noticed there was no Internet signal coming through. Upon opening the quick start guide, and found that 'a future update will enable this port'. Is this update available? Really disappointing as I can't use it for it's intended purpose.
- Blanca_ONETGEAR Employee Retired
Hi cerylidae22
Welcome to NETGEAR Community!
Failover feature is not enabled yet for LM1200 since the WAN port is not yet active. This is a pending future update.
Blanca
Community Team
- brian9658Aspirant
Blanca_O tellthebell wrote:Hi cerylidae22
Blanca
Community Team
Thanks a lot for help, i have same issue from last couple of days and can't able to find any proper solution on google.
Really appreciate for help.
- mmclean950Aspirant
piling on here... any news on the firmware release?
- JohnPengNETGEAR Expert
The failover feature will be available around the end of June with FW upgrade.
Sorry for the inconvenience.
Thanks
John
- RadiocookeAspirant
Any update on the release of the new Firmware, it's now officially past the end of June :smileyvery-happy:
Hi Radiocooke
Thank you for your interest. It is in the final stage of testing. Once completed, a firmware will be released that adds this function. Stay tuned!
Blanca
Community Team
