cerylidae22
Mar 04, 2021Follower
LM 1200 Failover
Recently bought LM1200 for use specifically as a failover. Connected the device, using a line in from my router to the WAN port and ran a line from the LAN port to my PC. I noticed there was no Inter...
sjbates2283
Aug 12, 2021Aspirant
I too bought 12 of these for this feature. Are you saying that I'll have to return them all and get another brand?
JohnPeng
Aug 12, 2021NETGEAR Expert
Confirm that 2-port FW will be officially released by the end of Aug. Please standby.
Sorry for the delay and thansk for your patience.
John
- Spenca87Aug 27, 2021Aspirant
Its pretty much the end of august any updates?
- civ_engSep 02, 2021Aspirant
August has come and gone. Please provide an update on this firmware release. Thank you.
- JohnPengSep 02, 2021NETGEAR Expert
The 2-port FW release has been posted online for upgrade. Currently, it is limited to the IMEIs ending with 0 and 1. We will add more later today or tomorrow to avoid stressing the upgrade server. Please advise the last digit of your IMEIs. I will add them first.
If you keep seeing Upgrade Error message, please do a factory reset and start over.
After upgrade, please do a factory reset and clear the browser cache to make sure the WebUI displays correctly.
Thanks
John
- civ_engSep 03, 2021Aspirant
Thank you for the good news John. My IMEI ends in 9.
