samodelkin's avatar
samodelkin
LM1200 - cannot connect to WebUI and also no cellular connection
Hello - I'm trying to set up a new LM1200 using RedPocket SIM (T-mobile compatible with a 1-year plan) and I'm having problems all around...   The modem doesn't seem to establish the cellular conn...
  • samodelkin's avatar
    Apr 11, 2024
    UPDATE: all problems resolved.
    • Regarding inability to get to WebUI, it was due to connecting it into the LAN in a wrong way (the device acts as a bridge/router, not as a client). Connecting a dedicated computer to the LAN port allowed me to access the UI at 192.168.1.5
    • Lack of cellular connectivity was due to the inability of the device to set the APN. Setting it manually enabled cellular connectivity.
