addisonElliott
Jan 19, 2023Follower
LM1200 - Manual DNS servers not working
I have a custom DNS server hosted in the cloud that I want to use for blacklisting domains. It's a public IP address and I know the DNS server works properly since I've used nslookup to test it on a ...
JohnPeng
Jan 20, 2023NETGEAR Expert
I think first please make sure the DNS IP can be access via the data connection through LM1200.
If this is not working, you can try to set up blacklist on LM1200 directly as a workaround.
Thanks
John
