DancingSamurai's avatar
Jan 31, 2023
LM1200 - Won't connect to correct APN
Hello,   I am trying to get the Netgear LM1200 to connect to the Internet via my mobile provider (Rogers).  I have a tablet SIM with a data plan and a static IP.   When I plug the SIM into the LM...
  • DancingSamurai's avatar
    Jan 31, 2023
    To reply to my own post - problem solved.
    The issue was the ISP had given me the wrong kind of static IP - one that only worked for 3G devices/connections. So the short term solution was to set the LM1200 to "WCDMA" instead of "Auto" for the network, and instant connection! (albeit at 1996 speeds - 10Mbit down 600kbps upload... yuck).
    Once the customer service guys are back in the office, they'll switch my account to an LTE static IP so I can get full speeds.
    Hopefully this post saves someone else 3 hours of their life... *sigh*.
