dennypage
May 31, 2025Initiate
LM1200-111NAS firmware
Hello, How can I get a firmware update for the LM1200-111NAS? Attempting to check for firmware update via the admin page gives: Update Error There was a problem updating your device. Pleas...
andyminr
Jun 20, 2025Tutor
Same problem. I bought the LM1200-111NAS directly from Netgear on May 21, 2025. I haven’t been able to update either online or by the suggested file. I have a case open with Netgear to see if they can provide a solution. Modem works with Verizon when there is a good signal. Not completely reliable as it will drop out whenever.
I would like to be able update the software to take advantage of fixes and improvements. This is what is done for most if not all of the software and firmware.
- wcoolnetJun 20, 2025Aspirant
How did you manage to open a case with Netgear? When I tried to open a support request online it wouldn't recognize the device serial number, so wouldn't let me proceed with opening a support request.
- andyminrJun 24, 2025Tutor
Initially Netgear didn’t recognize the S/N of the LM1200. I contacted them by phone to open a case. With an open case i sent screen shots of the labeling on the modem and box. Netgear support was able to register the modem.
