dennypage
May 31, 2025Initiate
LM1200-111NAS firmware
Hello, How can I get a firmware update for the LM1200-111NAS? Attempting to check for firmware update via the admin page gives: Update Error There was a problem updating your device. Pleas...
andyminr
Jun 20, 2025Tutor
Same problem. I bought the LM1200-111NAS directly from Netgear on May 21, 2025. I haven’t been able to update either online or by the suggested file. I have a case open with Netgear to see if they can provide a solution. Modem works with Verizon when there is a good signal. Not completely reliable as it will drop out whenever.
I would like to be able update the software to take advantage of fixes and improvements. This is what is done for most if not all of the software and firmware.
wcoolnet
Jun 20, 2025Aspirant
How did you manage to open a case with Netgear? When I tried to open a support request online it wouldn't recognize the device serial number, so wouldn't let me proceed with opening a support request.
- andyminrJun 24, 2025Tutor
Initially Netgear didn’t recognize the S/N of the LM1200. I contacted them by phone to open a case. With an open case i sent screen shots of the labeling on the modem and box. Netgear support was able to register the modem.
