The_Dave
Oct 07, 2021Aspirant
LM1200 4G LTE Modem Firmware Update Download
Hi all, I recently purchased an LM1200 modem. The device came with an older firmware version that doesn't yet have the WAN port enabled. I'm having some issues getting my LTE connection to work and w...
Oct 08, 2021Guru - Experienced User
to update it go to
Settings-->General--->software and reset
under software section, click on check for updates.
- The_DaveOct 13, 2021Aspirant
Thanks for the reply. I'd like to perform an offline update if possible, though. By downloading the firmware file and uploading it to the device.
- JohnPengOct 15, 2021NETGEAR Expert
Please let me know your device SKU. I can send you the offline update file. But this is not suggested way to have your device updated.
Thanks
- nrod86Oct 28, 2021Aspirant
I have an LM1200-100NAS that will not download the update over the air, have tried multiple times and gives an error every time, even after a factory reset. Can you please also send me the offline version. Thanks
Nick
