The_Dave
Oct 07, 2021Aspirant
LM1200 4G LTE Modem Firmware Update Download
Hi all, I recently purchased an LM1200 modem. The device came with an older firmware version that doesn't yet have the WAN port enabled. I'm having some issues getting my LTE connection to work and w...
Compound93
Dec 14, 2021Aspirant
Hi, I tried updating my LM1200 through the software update button, but each time it gives me an error and says to try again later. I have factory reset it and turned it off and left it off for about 30 minutes in case it needed a minute to rest. Any advice on what to do from here?
JohnPeng
Dec 14, 2021NETGEAR Expert
Please let me know your device's SKU. I will send you the upgrade package.
Thanks
John
- Compound93Dec 16, 2021Aspirant
it's the LM1200-100NAS one.
- brianatlargeDec 16, 2021Aspirant
I'm also unable to update the firmware.
I had it in in bridge mode and it just said it was downloading a firmware update, but it never got past 55%.
I changed it to router mode, and now it doesn't say it's downloading any update. When I click the button to check for an update, it says:
Update Error
There was a problem updating your device. Please try again later.Firmware
Firmware Version: EC25AFFDR07A09M4GApp Version: NTG9X07C_20.04.07.06Web App Version: LM1200-HDATA_03.03.103.189Hardware Version: 1.0
- stebuuJan 05, 2022Aspirant
JohnPeng : I also need the current firmware file for a LM1200-100NAS, but for a very odd reason. I'm doing initial setup with it with my Verizon SIM card, and if I have the SIM card in it looks like the router only operates in IPv6 mode and I can't get to modem control panel even using the IPv6 gateway address. If I don't have the SIM card in the router operates normally and 192.168.5.1 is accessible.
So right now I can either have the LM1200 connected to the internet or access its admin panel but not both simultaneously, so I can't update it.- JohnPengJan 05, 2022NETGEAR Expert
So right now I can either have the LM1200 connected to the internet or access its admin panel but not both simultaneously, so I can't update it.For the Verizon SIM issue, we are investigating right now. You can find the discusssion in another community post.
I will send you the FW release. Please check your private message.
Thanks
- jhebbelFeb 07, 2022Aspirant
I also have a LM1200-100NAS and my update also will not work when trying automatically. Can yousend methe firmware aswell.
