The_Dave
Oct 08, 2021Aspirant
LM1200 4G LTE Modem Firmware Update Download
Hi all, I recently purchased an LM1200 modem. The device came with an older firmware version that doesn't yet have the WAN port enabled. I'm having some issues getting my LTE connection to work and w...
JohnPeng
Dec 14, 2021NETGEAR Expert
Compound93 wrote:
Hi, I tried updating my LM1200 through the software update button, but each time it gives me an error and says to try again later. I have factory reset it and turned it off and left it off for about 30 minutes in case it needed a minute to rest. Any advice on what to do from here?
Please let me know your device's SKU. I will send you the upgrade package.
Thanks
John
Compound93
Dec 16, 2021Aspirant
it's the LM1200-100NAS one.
- brianatlargeDec 17, 2021Aspirant
I'm also unable to update the firmware.
I had it in in bridge mode and it just said it was downloading a firmware update, but it never got past 55%.
I changed it to router mode, and now it doesn't say it's downloading any update. When I click the button to check for an update, it says:
Update Error
There was a problem updating your device. Please try again later.Firmware
Firmware Version: EC25AFFDR07A09M4GApp Version: NTG9X07C_20.04.07.06Web App Version: LM1200-HDATA_03.03.103.189Hardware Version: 1.0
