The_Dave
Oct 07, 2021Aspirant
LM1200 4G LTE Modem Firmware Update Download
Hi all, I recently purchased an LM1200 modem. The device came with an older firmware version that doesn't yet have the WAN port enabled. I'm having some issues getting my LTE connection to work and w...
JohnPeng
Dec 14, 2021NETGEAR Expert
Compound93 wrote:
Hi, I tried updating my LM1200 through the software update button, but each time it gives me an error and says to try again later. I have factory reset it and turned it off and left it off for about 30 minutes in case it needed a minute to rest. Any advice on what to do from here?
Please let me know your device's SKU. I will send you the upgrade package.
Thanks
John
stebuu
Jan 05, 2022Aspirant
JohnPeng : I also need the current firmware file for a LM1200-100NAS, but for a very odd reason. I'm doing initial setup with it with my Verizon SIM card, and if I have the SIM card in it looks like the router only operates in IPv6 mode and I can't get to modem control panel even using the IPv6 gateway address. If I don't have the SIM card in the router operates normally and 192.168.5.1 is accessible.
So right now I can either have the LM1200 connected to the internet or access its admin panel but not both simultaneously, so I can't update it.
- JohnPengJan 05, 2022NETGEAR Expert
So right now I can either have the LM1200 connected to the internet or access its admin panel but not both simultaneously, so I can't update it.For the Verizon SIM issue, we are investigating right now. You can find the discusssion in another community post.
I will send you the FW release. Please check your private message.
Thanks
- jhebbelFeb 07, 2022Aspirant
I also have a LM1200-100NAS and my update also will not work when trying automatically. Can yousend methe firmware aswell.
- JohnPengFeb 07, 2022NETGEAR Expert
We have posted the LM1200 upgrade packages on the Netgear support page. Please download following the link below.
https://www.netgear.com/support/download/?model=LM1200
Let me know if you have any issues.
Regards
John
