The_Dave
Oct 07, 2021Aspirant
LM1200 4G LTE Modem Firmware Update Download
Hi all, I recently purchased an LM1200 modem. The device came with an older firmware version that doesn't yet have the WAN port enabled. I'm having some issues getting my LTE connection to work and w...
JohnPeng
Dec 09, 2021NETGEAR Expert
Glad you finally got the correct plan.
The device has been certified with AT&T, T-Mo and Verizon. So if you get their mobile hotspots BYOD plan, it will work with the device for sure. But we know that some promotion plans whihc tied to certain promoted devices will not work with the device.
Thanks
kanjiattache
Feb 12, 2022Aspirant
I have got one of these modems and I was looking into antennas until I realized I am practically in the shadow of the tower but the modem will not pick up the LTE signal, only the 3G signal, and in either case does not connect. The manual suggests that an APN may be needed but I have not found anyone at AT&T who knows what an APN is. I am using their BYOD mobile plan and worked with a represenative in the store to purchase the plan, even brought in the box so they knew in what type of device I was putting their SIM (IMEI checked out). The 3G signal is excellent but supposidly going away later this month. Choosing LTE only in the Network Mode menu does not display any reception details. Anyone know the solution to this?
- kanjiattacheFeb 12, 2022Aspirant
I am sorry this is technically off topic but connectivity seems to have been part of the discussion of firmware updates and I just wanted to share that recent Bing search revealed some options to try:
https://www.att.com/support/article/wireless/KM1062162
I am not sure if this is the proper answer for this device but using "Broadband" for the APN seems to work for me.
- JohnPengFeb 13, 2022NETGEAR Expert
Yes. broadband is the correct APN setting for this device on AT&T. I think the APN setting should be populated automatically for LM1200 with AT&T SIM. Please let me know if APN wasn't set automatically for you.
Thanks
