santimaster2000
Nov 30, 2021Follower
LM1200 4G LTE Modem Firmware won't update
I purchased an LM1200 LTE Modem/Router to serve as a fallback connection for my computer, the WAN feature seems to require a firmware update, I've tried updating through the web UI, but it keeps givi...
ThomasWheeler
Jan 07, 2022Aspirant
Same here spent a few hours with support they are no help. I was asking for a link to download the firmware and see if we can update it that way.
- JohnPengJan 09, 2022NETGEAR Expert
I will post a public link soon to the FW upgrade release. Please check your private message first,
Thanks
John
- simnettechMar 01, 2022Aspirant
Hi, just wondering if you can still post that link. Still seeing that LAN port issue with multiple LM1200 modems and hoping the firmware update will fix the issue.
Thanks,
SimNet Tech
My apologies, I found it on the Support site and downloaded the firmware from here:
https://kb.netgear.com/000064616/LM1200-LTE-Upgrade-Package-Retail-Australia-Europe-and-US
Thank you,
SimNet Tech
- Asandone1Aug 10, 2025Aspirant
Can you send me the correct fw as well I dl the update release given by net gear when typing in the model ans it says update failed
