santimaster2000
Nov 30, 2021Follower
LM1200 4G LTE Modem Firmware won't update
I purchased an LM1200 LTE Modem/Router to serve as a fallback connection for my computer, the WAN feature seems to require a firmware update, I've tried updating through the web UI, but it keeps givi...
Blanca_O
Mar 10, 2022NETGEAR Employee Retired
Hi Ferri
There are 3 LTE Upgrade packages available - Australia, Europe and US.
Please make sure that you download the right firmware for your device,
Download link page: https://www.netgear.com/support/product/lm1200.aspx#download
Ferri
Mar 10, 2022Aspirant
- FerriMar 15, 2022Aspirant
SKU : LM1200-100NAS
firmware : EC25AFFDR07A09M4G
APPVERSIONNTG9X07_20.06.09.00
hardware version 1.0
- Blanca_OMar 16, 2022NETGEAR Employee Retired
Hi Ferri
It appears that you have the latest firmware v20.06.09.00 installed.
Kindly access LM1200 settings page, go to Settings > General > Software and Reset > click the Check for update button. This will allow the modem to check for new firmware.
And for the manual update, did you load the SPK file and not the ZIP file?
Blanca
Community Team - FerriMar 19, 2022Aspirant
Still the same problem . Update with the 77.7 MB SPK file remains. Tried hard reset , update vis direct wire , soft reset , harsh reset . Nothing has worked. 2nd unit with the exact same problem . Something in the spk file is not compatible with the current firmware EC25AFFDR7A09M4G . SKU # lm1200-100nas . SN # 6ju314wjo2728 .
- JohnPengMar 19, 2022NETGEAR Expert
Please collect a model.json file and send back to me via private message.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
