n4mwd
Jan 09, 2022Aspirant
LM1200 Bridge mode not working
I just got my new LM1200 LTE modem and a T-mobile data sim card. The modem updated to new firmware without asking and now it doesn't work right. According to its web interface, it is in BRIDGE mode...
- Jan 09, 2022
Most of carriers don't support remote access to your network behind the LM200. This is not the issue of LM1200. Some carriers provide the special plan with VPN support that allows user to remote access the local network.
Thanks
John
n4mwd
JohnPeng wrote:Most of carriers don't support remote access to your network behind the LM200. This is not the issue of LM1200. Some carriers provide the special plan with VPN support that allows user to remote access the local network.
Thanks
John
At this point, what I know for sure is that the modem is not working in bridge mode and not passing through the public IP. The SIM is a special data sim that is suppossed to work in both directions. So the first step is to get working LM1200 firmware that allows bridge mode to work properly.
JohnPeng
Jan 09, 2022NETGEAR Expert
n4mwd wrote:
Thanks
John
We know that some T-Mo business plans support VPN and allow user to remote access the local network. Good luck.
Thanks
John
- n4mwdJan 09, 2022Aspirant
JohnPeng wrote:We know that some T-Mo business plans support VPN and allow user to remote access the local network. Good luck.
Thanks
John
I don't think this is a business SIM. Its a 30GB SIM that was designed for use with 4G and 5G modems. Standard phone SIMS from T-mobile don't allow tethering and will trap traffic from anything other than a phone. This one is data only with no phone or SMS.
Is there any reason I can't simply connect to a private or commercial VPN service? Or some other bidirectional tunneling protocol?
I doubt I'm the first person with this problem. Lots of people have IP cameras and would like to log into them.
- JohnPengJan 09, 2022NETGEAR Expert
Thanks
John
Definitely, you are not the first user having the issue. But this is restricted on the carrier networks.
- n4mwdJan 10, 2022Aspirant
JohnPeng wrote:Definitely, you are not the first user having the issue. But this is restricted on the carrier networks.
I did check on the T-Mobile forums and people are reporting the same problem with the T-Mobile supplied modems. The only proven cure is a VPN. Most are using commercial VPN's, but I am assuming that a private VPN (to an office or friend's house) will also work.
So far there has been nothing said about using IPV6. I am assuming that the reason they NAT is because of the shortage of IPv4 addresses. That isn't an issue with IPv6.
I still need to check to see if disabling Binge-On will have any effect, but I suspect not.
