Dashingbenjamin
Nov 15, 2022Tutor
LM1200 DHCP issue on new subnet
Hi all, I have purchased an LM1200 to act as 4G failover on an existing network. The existing network operates on the 192.168.20.0/24 subnet. As such, the network overview is: ISP modem -> LM1...
mli
Dec 05, 2022Tutor
Can the LM1200 DHCP service be made to function by any means at all?
E.g. by using whatever is the out-of-the-box subnet configuration such as 192.168.1.1/24 or 192.168.0.1/24 with only the router directly connected to one client.
Could small steps be then made to advance to the desired configuration to see when DHCP functionality breaks?
- DashingbenjaminDec 06, 2022TutorHi Mli,
Only on the default subnet 192.168.5.x/24
If I change it at all, even just the third octet, it fails completely.
I tried 192.168.1.x/24, 192.168.20.x/24, 10.0.0.x/24 and none worked.- mliDec 11, 2022Tutor
Is it possible to leave this non-cooperative device on its default subnet and reconfigure the rest of the network to be compatible with this?
It may be that after several days, the root cause may become obvious and then you can move everything to the desired configuration.
