shawnsbrain66
Nov 02, 2022Follower
LM1200 doesn't see/detect SIM card
I have a new LM1200. I have a known good Verizon SIM card (it works if I plug it into a phone). When I put it into the LM1200, it says "SIM NOT DETECTED". I've tried putting the card in different ...
JohnPeng
Nov 02, 2022NETGEAR Expert
There is only one way you can insert the SIM in the slot. You will feel the click when it is inserted properly.
I suggest you to request a replacement if it is confirmed the device really can't detect the SIM card properly.
Thanks
John
