jparchitect
Jan 17, 2022Aspirant
LM1200 drops internet after 6 hours when used as failover
I hooked up a LM1200 between my FIOS ONT and Netgear Nighthawk X10 WIRELESS AD7200 Router. Using ATT SIM CARD. After some headaches getting the proper APN from ATT finally got it all seemingly workin...
JohnPeng
Jan 17, 2022NETGEAR Expert
For your case, please try to enable keepalive timer and use the default keepalive timer setting. It will help.
Please let me know if you still see the issue after enabling the timer.
Thanks
jparchitect
Is the keepalive timer a setting on the router or the LM1200 LTE modem? I am not familiar with what you are talking about so I appreciate an explanation if you can. Thanks!
- JohnPengJan 17, 2022NETGEAR Expert
Sorry. The setting is on LM1200.
Please log in to WebUI by visiting 192.168.5.1. The admin log password can be found on the product label.
Then go to Settings -> Advanced -> Failover -> Select radio button On for Keepalive.
Thanks
- jparchitectJan 17, 2022Aspirant
Thanks! i found it. there are some other keepalive settings too (keepalive interval) and a ping configuration. do I need to change anything with these or keep the default?
Just keep everyong else with default values.
Thanks
