Todd_P
Nov 14, 2021Aspirant
LM1200 fails updating / checking firmware, no WAN feature
I recently purchased the LM1200 and found that the WAN feature is not enabled. I have attempted on several occasions to update the firmware by navagating to Settings > Software and Reset > Check for ...
JohnPeng
Nov 15, 2021NETGEAR Expert
Please do factory reset and try again.
If you still have the issue, I will sedn you the local FW upgrade package for you to upgrade your device using Web GUI.
Thanks
- Todd_PNov 16, 2021Aspirant
John,
Thank you for the assistance. Unfortunatly, I am still receiving the same error.
I tried factory resetting with and without the SIM installed just to be sure and it still will not update itself. - mmoyer2655Jun 04, 2025Tutor
Hello John. I have the same issue updating my LM1200-111NAS. Would you be able to send me the local FW upgrade?
Like
