Todd_P
Nov 14, 2021Aspirant
LM1200 fails updating / checking firmware, no WAN feature
I recently purchased the LM1200 and found that the WAN feature is not enabled. I have attempted on several occasions to update the firmware by navagating to Settings > Software and Reset > Check for ...
WebFeet
Jul 01, 2025Tutor
Same problem. A private message solution is not a solution if it can't be shared with the community
