danlo315
Sep 21, 2022Tutor
LM1200 falling back to WAN issue
I realized the post I made was in response to a topic that was marked as resolved, so starting a new thread. Just bought the LM1200 and done the following: - running latest firmware (NTG9X07C...
mbill002
Sep 26, 2022Aspirant
Have you found any solution? I am facing the same issue. The modem switches to LTE when the cable line goes down or I turn off the cable modem. But when it comes back, it does not switch back to wireline nor it stays with LTE - the line just stays down.
danlo315
Sep 26, 2022Tutor
No I have not. I also just experienced a weird bug where my modem looked fine but the LM1200 just disconnected the main line and did not kick in LTE. This lasted about 2 minutes before it came back online. I will probably have to invest in utilizing my Edgerouter 4's failover instead of using LM1200's failover.
- mbill002Sep 26, 2022AspirantUnfortunately thats not an option for me since my router is not dual wan. My option would be to go for a tplink modem + er605 type router with failover combo. The combined price of these two is similar to the LM1200
