danlo315
Sep 21, 2022Tutor
LM1200 falling back to WAN issue
I realized the post I made was in response to a topic that was marked as resolved, so starting a new thread. Just bought the LM1200 and done the following: - running latest firmware (NTG9X07C...
thewrz
Sep 29, 2022Tutor
I am having the exact same issue. I would have replied to your thread with my scenario but I posted a new topic here:
Basically yeah. Works fine on LTE. But switch back to modem and nothing happens. I even get an SMS that the LM1200 switched back to "wireline" -- but my Orbi router still doesn't work.
I tried rebooting the LM1200 with just the cable modem plugged into the WAN. And I tried rebooting the Orbi router. Still nothing. I can only get Internet to come across to the LAN side if the LM1200 is connected to LTE only.
- danlo315Sep 29, 2022TutorUnfortunately I had to give up using the LM1200 for failover purpose. I ended up using my Ubiquiti Edgerouter 4's multi WAN failover functionality instead.
- mbill002Sep 29, 2022Aspirantdanlo315 did you set the default connection to “mobile broadband only” ? And do you have the keep alive turned on? I am getting an edgerouter X today and planning to setup failover there.
- danlo315Sep 29, 2022TutorI tried both (failover as well as mobile only) but didn't really make much of a difference. Keepalive is on.
Going through the EdgeOS GUI's failover wizard did the trick. Be sure to mark the second WAN as failover *only* unless you want to combine bandwidth.
