danlo315
Sep 21, 2022Tutor
LM1200 falling back to WAN issue
I realized the post I made was in response to a topic that was marked as resolved, so starting a new thread. Just bought the LM1200 and done the following: - running latest firmware (NTG9X07C...
mbill002
Sep 29, 2022Aspirant
danlo315 did you set the default connection to “mobile broadband only” ? And do you have the keep alive turned on? I am getting an edgerouter X today and planning to setup failover there.
danlo315
Sep 29, 2022Tutor
I tried both (failover as well as mobile only) but didn't really make much of a difference. Keepalive is on.
Going through the EdgeOS GUI's failover wizard did the trick. Be sure to mark the second WAN as failover *only* unless you want to combine bandwidth.
