danlo315
Sep 21, 2022Tutor
LM1200 falling back to WAN issue
I realized the post I made was in response to a topic that was marked as resolved, so starting a new thread. Just bought the LM1200 and done the following: - running latest firmware (NTG9X07C...
mopoke
Oct 04, 2022Aspirant
I am having the same issue with my lm1200. The failover to the wireless internet works fine but switching back to the wireline fails. Power cycling the lm1200 brings it back.
This makes the device completely useless for the purpose for which I bought it. Is there any way of fixing it or do I need to return ?
- danlo315Oct 04, 2022TutorUnfortunately it doesn't seem like it, as Netgear reps aren't replying to this post. However I can't find a similar product that does failover.
- mbill002Oct 04, 2022AspirantHere is what I ended up doing. Purchased a edgerouter-X for $59 (available on their website). Using it as my main router in dual wan failover setup. Also, there is another bug in lm1200 that makes it reboot randomly if you have verizon sim in bridge mode. So I had to switch to router mode. With my cable modem connected to primary wan and lm1200 to secondary wan of the edgerouter and a little bit of configuration, the setup is now working without any issues.
