danlo315
Sep 21, 2022Tutor
LM1200 falling back to WAN issue
I realized the post I made was in response to a topic that was marked as resolved, so starting a new thread. Just bought the LM1200 and done the following: - running latest firmware (NTG9X07C...
danlo315
Oct 04, 2022Tutor
Unfortunately it doesn't seem like it, as Netgear reps aren't replying to this post. However I can't find a similar product that does failover.
mbill002
Oct 04, 2022Aspirant
Here is what I ended up doing. Purchased a edgerouter-X for $59 (available on their website). Using it as my main router in dual wan failover setup. Also, there is another bug in lm1200 that makes it reboot randomly if you have verizon sim in bridge mode. So I had to switch to router mode. With my cable modem connected to primary wan and lm1200 to secondary wan of the edgerouter and a little bit of configuration, the setup is now working without any issues.
