Davidbobcats
Jul 15, 2022Aspirant
Lm1200 green light but no internet
Need help. Cannot connect to the internet but when I log in on the Lm1200 it shows I am connected. Received a new Sim card for att and it worked for an hr than no connection.
michaelkenward
Jul 16, 2022Guru - Experienced User
You might have to explain this in a bit more detail.
What does "Cannot connect" mean? What tells you that?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual on troubleshooting.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
Davidbobcats
Jul 18, 2022Aspirant
- DavidbobcatsJul 18, 2022Aspirant
I posted a picture that shows i am connected to the internet but i cant connect to the web.
- michaelkenwardJul 18, 2022Guru - Experienced User
Who, or what, is wireline?
Search - NETGEAR Communities – wireline
Is there something else on your network that it expects to find? Looking at the manual that seems to be an option.
It may be that the thing is telling you that you don't have something plugged into the WAN port. But you shouldn't need that to connect to the Internet.
Maybe that message has nothing to do with your mobile connection and you need to look elsewhere for solutions to that issue.
You probably need help from one of the experts in mobile routers.
By the way, Alt+PrintScreen is usually easier than messing around d with pointing a camera at a screen.
