Toshia_Renee
Mar 12, 2021Follower
LM1200 green light no internet
I have my LM1200 connected to a tp-link wireless router and I had internet for maybe 2 hours then it said no internet but my devices are connected. My modem and routers lights are green and showing ev...
Blanca_O
Apr 15, 2021NETGEAR Employee Retired
JohnPeng
May 03, 2021NETGEAR Expert
Sorry for replying late.
Are you still experiencing the connection issue? If so, could you please send private message to me of your contacts? I will reahc out to you to find some details.
Thanks
John
- t-valMay 13, 2021Aspirant
Has there been a resolution to this? I have experienced the same problem. I had internet for only a few minutes. Ran a speed test and it completed the download portion, and died somewhere in the upload. Unable get any internet ever since. Factory reset with no success.
The modem still reports as connected. In fact, it successfully text me a low data warning. I have tried both router mode (directly connected to my PC) and bridge mode (through my home router) and both fail to provide internet. The modem is able to check for new firmware successfully. So it sure seems like LTE connection is fine and that the problem lies in actually converting it to an ethernet connection.
- JohnPengMay 16, 2021NETGEAR Expert
To resolve the connection issue, please log in to WebUI and check the APN setting. If there are multiple APNs associated with your SIM card, please select the radio button in front of the APN that matches with your SIM card.
Then wait for data connection is set up again and WebUI is reloaded. Log in to WebUi to check the data connection again.
Thanks
- DanbuAug 13, 2021AspirantSet LM1200 up with tp link router 2 days ago. Worked perfectly. Now no internet. All lights are green and router says it’s connected but still no internet. I see this is a common issue, was wondering what the fix has been for everyone
- JohnPengAug 13, 2021NETGEAR Expert
We have improved the connection stability in the new releases. Please wait for the official FW upgrade with 2-port feature support by the end of Aug.
Thanks
- DavidbobcatsJul 18, 2022Aspirant
Has anyone found a solution to this? Im experiencing the same problem.
- t-valJul 18, 2022Aspirant
I ended up switching MVNOs to resolve. Tello working great for me. FreedomPop caused this issue for me.
