schmittalvin
Nov 17, 2021Aspirant
LM1200 imei number and gen quest
I need the imei number before I can buy in order to know if it works with TING. also I will be running it on DC so if it is on (powered on) all the time will I be charged anything or can I leave it o...
JohnPeng
Nov 19, 2021NETGEAR Expert
schmittalvin wrote:
I need the imei number before I can buy in order to know if it works with TING. also I will be running it on DC so if it is on (powered on) all the time will I be charged anything or can I leave it on all the time?
You can use the device's IMEI TAC code: 25631611 to check whether the device is compatible or not.
The device dooesn't use battery. It needs to be powered on with Power Adaptor.
Thanks
- schmittalvinNov 19, 2021Aspirant
I am an electrical engineer with over 50 years experience so I know how to power the device with a car battery even if i have to conver to 60 hz 120vac.
- JohnPengNov 19, 2021NETGEAR Expert
It will not use extra data if you keep it on 24/7 if you don't have device connecting to it.
Thanks
