bigbillsdd
Nov 24, 2021Aspirant
LM1200 IMEI on CricketWireless says its not compatible. (Its ATT)
Model = LM1200 Not available in the Model Picklist when creating this thread. I just purchase one of these to use with Cricketwireless on their 100GB for $50 plan. They says its not compatab...
Nov 24, 2021Guru - Experienced User
It has to be a cricket approved device. You'd have to check with cricket to see what they support.
bigbillsdd
They have no such list. Only their #2 hotspot which is an even slower device than the LM1200. And their hotspots specs says its also 3g. It makes me wonder why they car what hotspot is used. The plan I am looking at is 100GB per month, then its useless till the new month. I looked at visible, no coverage in Mexico and Canada. Which Cricket does a really decent job in those countries. -Bill
- plemansNov 25, 2021Guru - Experienced User
I wish it was something netgear controlled but its all cricket controlled as to what devices they approve
- bigbillsddDec 02, 2021Aspirant
Netgear does control what modem is in it. Modems with 3G shouldn't be in hotspots for the US anymore, and this is a fairly new model (2021). -Bill
