mm2015yogi
May 26, 2021Tutor
LM1200 LTE 4G modem can't connect to AX1800 RAX 10 router
I have a brand new Netgear AX1800 RAX10 WIFI 6 router (about 1 week old) and today, I purchased the Netgear LM1200 4G LTE modem. I followed the directions in the modem booklet and inserted my T-Mobil...
michaelkenward
May 28, 2021Guru - Experienced User
The LM1200 is a modem-router. So you are adding a router after a router. That needs careful configuration.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
Check the section in the manual Connect a Computer, Router, or WiFi Router
to the Modem.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
