devan_b
May 16, 2021Aspirant
LM1200 modem filtering ipv6 packets?
I recently purchased a netgear LM1200 and have been able to configure it as a WAN for my router. Outgoing traffic flows well. I would like to set it up as an end point for a VPN server using the...
User23562346
May 17, 2021Aspirant
Any luck?
I just got mine setup and outbound traffic is fine, but can't do inbound traffic. The thing is in bridge mode so I don't expect it to be filtering but inbound HTTPS, OpenVPN, and even ping doesn't work.
devan_b
No luck. I am a bit of a novice with ipv6 but I am only getting IGMP traffic from the modem to the router. When I try to ping the ipv6 address Nothing is received by the router.
- User23562346May 17, 2021Aspirant
I'm using a Tello sim. My guess is Tello just by default blocks inbound content if htere's no matching state. For me IPv4 or IPv6 would be fine, neither work. However, from the router I can ping on either and things appear to work fine.
Next step is to contact Tello and ask them if we can get an "unrestricted" connection (perhaps with a dedicated IP - though I don't need one). It's possible only the bigger carriers can do this.
- devan_bMay 18, 2021Aspirant
I'm also using Tello which is using t-mobile.
After reading many threads on t-mobile and reddit, I realize that many people are trying to get inbound connections via IPv6. One reported success running a webserver on a phone. No one else and no one on a modem. The consensus is that t-mobile is filtering all inbound data, even ping.
Interestingly someone with ATT tried on an older netgear modem and was able to receive inbound packets. Plans start at 25 / month which is a bit more that the 6 I am paying now.
