Dugymd
Aug 18, 2021Aspirant
LM1200 netgear modem I can’t get it to configure my lte network.
Dugymd
Aug 21, 2021Aspirant
I’m in US. The carrier is called visible. They use Verizon towers. It’s a data sim. All the rearch I’ve done before purchasing this set up led me to believe it was plug and play with this network. Would there be anyway to get it to work but changing apn ? Im spitballing here not even sure if that makes sense. NOVICE here
AyeAyeAye
Aug 21, 2021Apprentice
LM1200
B2, B4, B5, B12, B13, B14, B66, B71
Visible LTE bands
2, 4, 5, 13, 66.
Hotspot (phone) is 5Mbps speed restricted on Visible, how they apply sims to a LTE modem I’m not sure but I’d guess IMEI is barred as a broadband device & it has to be a Mobile Phone device that’s Verizon supports I’d guess.
Use a 4G/5G phone with 4x4 mimo/carrier aggregation and a ASUS
(Or other) router that supports usb tethering from a Android.
The 5Mbps hotspot also can’t be used with only with 1 device on a iPhone, Apple don’t hand control of these things like Android/carriers do.
Visible LTE bands
2, 4, 5, 13, 66.
- AyeAyeAyeAug 21, 2021Apprentice“ The SIM card works well in any phone that I try it in and also works in a Netgear Nighthawk M1 after I use the VSBLINTERNET APN.“
https://forum.gl-inet.com/t/gl-mifi-or-mudi-with-visible/11469
