Dugymd
Aug 18, 2021Aspirant
LM1200 netgear modem I can’t get it to configure my lte network.
Réda
Oct 29, 2021Aspirant
Hi,
Just new here and testing for first time LTE Modem LM1200 and AX1800 Wifi routeur RAX10, so sharing my experience...
I'm in France.
LTE Modem LM1200 works fine here (Bouygues Telecom).
I first tried Modem LM1200.
Inserted an active SIM-data plan.
Connect LAN cable on same switch as my computers, all configured with DHCP for sure.
Connect power and switch on.
After a while, 4G light desesperatly red....
my computer get an 192.168.5.x IP address on LAN (no wan...on modem...).
web browser on 192.168.5.1.
connect with password...OK
The page say me my SIM is code pretected... type the code, ok
Deactivate code on SIM...
Change password
reboot
4G green lights.
Ping on 8.8.8.8 ok !!!
connect with new password...OK
Clik on parameters, then Advanced
Choose for "Router" on "Operation Modes", Bridge is default...
==> "When set to Bridge, this option turns off the router function of the device and assigns the network IP address directly to the attached host. This option can be useful for implementing secure, enterprise VPNs."
cool...
Click on "Send" to change config...
Then, with router config, I can change IP address for 192.168.1.1 and change the range of DHCP distibution...
Then I change the LAN cable of modem LM1200 and connect it to "WAN" port of AX1800 Wifi routeur RAX10.
And the switch of my computers connected to LAN PORT of AX1800 Wifi routeur RAX10.
Power on, initialising, connecting and finally all leds green.
ping on 8.8.8.8 work fine !
Cheking my computers, are on 10.0.0.x LAN segment, and wifi too.
I connect on 10.0.0.1 on web browser, change password and adjust WIFI parameters...
So LM1200 give an 192.168.1.x adsress to AX1800 Wifi routeur RAX10 on wan.
AX1800 Wifi routeur RAX10 is with 192.168.1.x by default. (know that because I maked some config's trying...), automatic config redesigned LAN with 10.0.0.x...
Very stable, work fine...
