selittle's avatar
selittle
Follower
Aug 31, 2021
lm1200 no signal light
So I just activated my lm1200 with a t-mobile plan from RC-4G. Prior to activation it was picking up a signal with a green light. After activation the signal light went dark. does this mean I am now picking up no signal at all? That the plan is perhaps using frequencies no provided by the closer towers?
  • michaelkenward's avatar
    michaelkenward
    That's a mobile modem. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
