twern
Mar 07, 2022Aspirant
LM1200 no VoLTE but is compatible with Verizon and T-Mobile???
Netgear indicates that the LM1200 modem is compatible with T-Mobile and Verizon yet both online sites don't show this device listed and indicate that the mdem needs to be VoLTE which I believe the LM...
Blanca_O
Mar 14, 2022NETGEAR Employee Retired
Hi twern,
Welcome to NETGEAR Community!
LM1200 will work with T-Mobile and Verizon network.
You may check this link:
Which mobile carriers are compatible with my NETGEAR mobile WiFi or fixed wireless device?
Blanca
Community Team
timhockley
Apr 26, 2022Aspirant
I talked to several VZ support folks and hotspot devices with third party devices are like speaking a foreign language to them. While your device may be certified on a carrier's network that doesn't mean it'll work with all of their plans. The last support person I got (after much research) said the LM1200 will only work on their home internet plans - not the mobile hotspot plans. So it would be very helpful if Netgear could go one step further and add what carrier plans their devices are certified for. In my case their home internet is not available where I need it.
