bmwalton14
Apr 05, 2021Follower
lm1200 not working on mobile data
I bought my lm1200 modem with the understanding that with the unlimated straight talk plan, that it would work on the unlimated data network. Upon using it for about a week, it suddenly disconnect fr...
JohnPeng
Jul 29, 2021NETGEAR Expert
Berylfyre wrote:
Could you tell me how you even set the modem up on straight talk please? I cant get it to accept the imei #. i can hardly hear or understand customer support.
Do you know which network your Straight Talk uses? Could you please capture a model.json file and send the provide message to me?
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
Thanks
hyperfive
Dec 06, 2021Tutor
I am having the same issue. It seems to be using a small amount of data and the rest hotspot data. How can I get it to use only regular data on T-Mobile
- Richard0704Feb 03, 2022AspirantHi I have the same problem my lm1200 is using just the mobile hotspot, have anyone solve this problem yet?
- JohnPengFeb 05, 2022NETGEAR Expert
Richard0704 wrote:
Hi I have the same problem my lm1200 is using just the mobile hotspot, have anyone solve this problem yet?Please advise the carrier and SIM plan used. Seems you SIM card support phone data plan and also mobiel hotspot data plan with one card. Please ask your carrier how they separate the 2 plans on the network side, using different APNs?
Thanks
- Richard0704Feb 05, 2022AspirantI use a tmobile plan for a cellphone I just remove the SIM card from the cellphone an inserted in the modem. I will go to a T-Mobile and ask about it.
