TD62's avatar
TD62
Lm1200 signal drop
I purchased an LTE modem in December 2022. It was working great, now constantly drops signal. Have tried resetting factory settings, no change. Using through cell signal booster but WiFi signal is stronger when I port cell data directly rather than going through modem. Something had definitely changed. Frustrated. Help please.
    • TD62's avatar
      TD62
      Thanks for that info however I have no idea what my login is.
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        The login info is printed on the product label at the bottom of the device.
        Thanks
