CoraDean33
Feb 24, 2021Follower
LM1200 SIM card purchase
I'm stuck at the very beginning. The SIM card. I want an unlimited plan. Do I have to purchase a phone with a SIM in it and pay on a month to month basis. What is the best way to get a SIM card? I'm ...
michaelkenward
Feb 25, 2021Guru - Experienced User
It will depend on where you are and which mobile operator you plan to use.
For example, here in the UK I can get a SIM from EE that I can use in any mobile device I like. Look for "SIM only" deals:
I assume that your LM1200LTE came with no tie to a particular mobile operator.
JohnPeng
May 03, 2021NETGEAR Expert
Most of carriers support data only plan to be used with such type of devices. For LM1200 sold in US, you can get the plan from AT&T, T-Mobile, Verizon and other MVNOs. When using MNVOs, you may need to manually configure the APN on the device.
John
