CFesta
Aug 10, 2023Tutor
LM1200: Throughput 2
Good morning. I just bought a LM1200, it works as expected for now. However, I have a degradation of the wired connection in download speed and ping. Without the device (router directly connecte...
schumaku
Aug 10, 2023Guru - Experienced User
From what I understand, there is not Ethernet hardware switch, much more the LM1200 (and similar devices with a dual LAN and WAN port) are implemented on a software bridge. JohnPeng or mcuadrado have certainly some more insight.
"just updated" isn't the greatest information where a version number would be much more informative. But i understand such an impact for what is supposed to driving a typical 1 Gb Internet connection isn't acceptable.
- CFestaAug 10, 2023TutorFirmware Version:EC25EUGAR07A01M4G
App Version:NTG9X07W_20.06.09.00
Web App Version:LM1200-HDATA_03.03.103.201
Hardware Version:1.0- schumakuAug 10, 2023Guru - Experienced User
CFesta wrote:
App Version:NTG9X07W_20.06.09.00This reads like the LM1200 LTE Upgrade Package (Retail-Australia, Europe and US) version from February 2022, which says:
Bug Fixes:
- Fixes the TP throttling issue with 2-port failover support
- Fixes failover stability issue.
Tempted to state the throttling issue with the TP throttling issue with 2-port failover isn't fully fixed. Or I don't understand the message in these Release Notes. Sorry @JohnPeng and @mcuadrado : More work for RD!
- mcuadradoAug 11, 2023Guide
Can you guys describe which tools are you using to measure your tput ? internally we use iperfv2 and iperfv3 . I just want to understand the scenario and try to replicate here.
