CFesta
Aug 10, 2023Tutor
LM1200: Throughput 2
Good morning. I just bought a LM1200, it works as expected for now. However, I have a degradation of the wired connection in download speed and ping. Without the device (router directly connecte...
schumaku
Aug 10, 2023Guru - Experienced User
CFesta wrote:
App Version:NTG9X07W_20.06.09.00
This reads like the LM1200 LTE Upgrade Package (Retail-Australia, Europe and US) version from February 2022, which says:
Bug Fixes:
- Fixes the TP throttling issue with 2-port failover support
- Fixes failover stability issue.
Tempted to state the throttling issue with the TP throttling issue with 2-port failover isn't fully fixed. Or I don't understand the message in these Release Notes. Sorry @JohnPeng and @mcuadrado : More work for RD!
mcuadrado
Aug 11, 2023Guide
Can you guys describe which tools are you using to measure your tput ? internally we use iperfv2 and iperfv3 . I just want to understand the scenario and try to replicate here.
- CFestaAug 11, 2023TutorHi,
I have a Netgear Nighthawk router connected to the Netgear LM100 which is connected to the ISP provided modem.
I enter in the Nighthawk App and I just perform the speed test. That's how I get the results mentioned in the first message. I tried these tests several times, removing and introducing the LM1200: the difference and the results are clear.
However, I also have performed normal speed test from other client devices using https://www.speedtest.net. The download speed it's slowed down by 200Mbps.
I checked the firmware version mentioned in the schumaku answer (Netgear support website), it's definitely the last one.
Anyhow, I also tried to download and install the last firmware version (Europe) but an error comes up (probably that's because I am trying to install the same version of the already present firmware). In any case, my LM1200 has the last available firmware installed.- schumakuAug 11, 2023Guru - Experienced User
CFesta wrote:
I have a Netgear Nighthawk router connected to the Netgear LM1200 which is connected to the ISP provided modem.
However, I also have performed normal speed test from other client devices using https://www.speedtest.net. The download speed it's slowed down by 200Mbps.The code called by the App running on the Nighthawk router is an industry standard Speedtest.net client, well known to Netgear. Not a critical test, no massive small UDP packets known to limit an weak Ethernet bridge code involved.
