g8rvet
May 30, 2022Initiate
LM1200 Upload speed on Ethernet Switch
Purchased a flat panel antenna and checked that it worked. Got good upload and download when connected directly to computer (through a punch down panel in my internet closet). Did final testing and...
May 31, 2022Guru - Experienced User
an unmanaged switch really shouldn't be affecting anything.
It could be the tv's downloading something in the background.
Have you tested them separate? What I mean is just the LM1200---switch--->computer with nothing else connected?
- g8rvetMay 31, 2022Initiate
Thanks so much. That is what I thought. I did exactly that last night and found one of the antennas to the router was not fully engaged (TS9 is a crazy port - so easy to accidentally unplug).
