oceanwolf's avatar
oceanwolf
LM1200 wan connection not working
I want to use LM1200 as a failover device in the North Sierras where when we lose power, the broadband goes out in 20 mins. I have the latest firmware and if I connect only LTE modem it works fine. F...
  • oceanwolf's avatar
    Jan 23, 2022
    Thank you John.
    I switched to Router mode and I was able get the traffic through. That caused me another problem since the port numbers using public IP was not translated to local IP.
    I switched to Bridge mode again and modem stayed connected and everything works great.
    Thanks for all the help, now I need to find external antennas to improve the LTE reception.
